S8 Max Series
S8 Max Series
FlexiArm Design™ Side Brush
Extra Edge Mop
DuoRoller Riser™ Brush
VibraRise® 3.0 Mopping System
8-in-1 Hands-Free Dock
Reactive AI 2.0 Obstacle Avoidance
“Hello Rocky” Intelligent Voice Assistant
S8 Max Ultra
Cleaning Beyond Limits.
Get ready for the S8 Max Ultra’s superior cleaning performance. With total corner-to-edge cleaning, advanced mopping, and smooth navigation, your floors have never looked better. The RockDock® Ultra and easy-to-use App set a new standard for convenient floor care.
S8 Max Ultra
  • Manual Water Replacement
  • Flexible Base Station Placement
S8 Max Ultra with Refill & Drainage System
  • Automated Water Replacement
  • Pre-Check for Installation Required
Visible Cleanliness in Invisible Areas This is a image
100% Concave Corner Coverage3
FlexiArm Design™
Side Brush
Conquer Every Corner
Unique to Roborock, the FlexiArm Design™ automatically extends the side brush when corners, and low areas below furniture are detected, allowing S8 Max Ultra to sweep up dirt from hard-to-reach spaces.2
1.68mm Along the Edge4
185rpm Rotating Speed5
1.68mm Along the Edge4 185rpm Rotating Speed5
Extra Edge
Mopping System
Extra Cleanliness, Perfected to Millimeter
Say goodbye to missed spots and hello to pristine floors. The innovative rotating side mop ensures precise cleanliness by effortlessly mopping closer to the edges, achieving impressive margins of less than 1.68mm.
Twice the Upgrade,
Twice the Strength
Achieve greater vacuuming efficiency across all floor types and ensure fewer hair tangles thanks to the power of the dual-roller brush, designed for a cleaner, hassle-free environment.
Less hair tangled
with concealed scrapers
0Pa
Extreme Suction
Unleash the power of the S8 Max Ultra with its unparalleled 8,000Pa HyperForce® suction capability5. Prepare to be amazed as your home transforms into a spotless haven.
Roborock Carpet Boost+ System™
Spotless Carpets Made Easy
Get better carpet care with a 99.5%6 hair pick-up rate using the Roborock Carpet Boost+ System™.
Carpet Boost This is a image
The robot detects carpets with ultrasonic sound, offering options to ignore, avoid, cross, or vacuum them while the mop is lifted.
When vacuuming carpets, the DuoRoller Riser™ brush, coupled with the auto-increased suction power, eliminates messes from carpets with superior efficiency.
Deep Carpet Cleaning This is a image
The carpets will be cleaned one more time7, forming a checkerboard pattern, improving the carpet cleaning effectiveness.
Vacuum Carpet First This is a image
In either vacuum-only or vacuum&mop mode, selecting 'Vacuum Carpet First' prompts the robot to prioritize carpet vacuuming with a dry mop and ensures you fresh carpets.8
VibraRise® 3.0 Mopping System Redefining Sonic Mopping Excellence Featuring double vibration modules, the upgraded mop effortlessly manages dust, dirt, and dried-on stains through its 4000 times/min high-speed scrubbing. It lifts up to 20mm above the ground while cleaning carpets, allowing simultaneous vacuuming and mopping without causing unwanted dampness.
2X Vibration Modules
4000times/min Sonic Mopping9
20mm Lifted Above Surfaces10
Liftable Brush and Mop
Divide and Conquer
The brushes and mop boast a liftable design and adjust automatically, maximizing cleaning efficiency while preventing any staining of the freshly cleaned floor.
Brush Lifted Mop Lifted Brush & Mop Lifted
  • During Mop-only Mode
  • During Vacuum-only Mode
  • During Carpet Cleaning
  • During Mop Drying
  • When Returning to Dock
The 8-in-1 RockDock® Ultra
A Leap in Hands-Free Convenience
Ultra
This is a image Heated Air Drying
This is a image 30% Faster Charging11 & Off-Peak Charging
Take Hands-Free to the Next Level On top of these maintenance-free features of the S8 Max Ultra, we've introduced a refill and drainage variant, taking your hands-free cleaning even further.
Auto Water Refill and Drain Refills clean water and empties dirty water automatically during mop washing and tank refilling, giving you a hands-free experience like never before.
Compact Design Seamlessly fits in your home environment and saves space with an impressive dock height of just 30cm.
Check Your Environment Please confirm the dock position and water pipe connections in advance, ensuring compliance with the following installation conditions. Space Requirements
  • 1Clean Water Inlet
  • 2Power Plug
  • 3Dirty Water Outlet
  • 4More than 100cm
  • 5More than 42cm
  • 6More than 30.5cm
This is a image Placed on a hard and flat floor
This is a image Strong Wi-Fi coverage
This is a image Avoid direct sunlight and humid environments
Installation Requirements
  1. 1.Reserve a space of at least: 30.5cm (1.0ft) in height, 42cm (1.4ft)in width, and 100cm (3.3ft) in depth.
  2. 2.The dock should be placed against a wall on a hard and even floor (wood, tile, concrete, etc.). Avoid placing it on soft surfaces (carpet, mat, etc.) and in narrow areas.
  4. 4.The height difference at any point on the drainage pipeline from the ground is recommended not to exceed 50cm(1.6ft).
  5. 5.The installation distance for the water refill and outlet pipes is recommended within 6 meters(19.7ft). If not, please contact customer service for consultation.
  7. 7.Please avoid arranging pipes through doorways or corridors.
  8. 8.Ensure there are no thresholds, tracks, or steps higher than 2cm between the dock's installation site and the cleaning area to avoid the risk of getting stuck or missed cleaning.
  9. 9.Before installation, please disconnect the power supply of the dock. Turn off the main water supply switch, faucet switch, or angle valve switch in the house. Drain pipelines, ensure they are connected without leakage.
Bacteria Removal Rate13
With up to 60℃ (140℉) hot water mop washing12, stubborn and greasy stains are easily dissolved from the mop, and the mop is also disinfected. This makes it sterile and suitable for kitchen and dining areas.
For Re-Wash During mop washing, detection continuously checks how dirty the mop is to adjust mop-washing duration, for optimal cleanliness.
For Re-Mop In heavily soiled areas, the floors will be mopped again to ensure a perfect clean.
Auto Detergent Dispenser The detergent is dispensed automatically, so you don’t need to fill in the detergent every time and worry about the proportion. With a spacious 580ml detergent tank, fill it once to support over 3 months.14
Dock Self-Cleaning The innovative self-cleaning design cleans the bottom of the dock to save you time and effort.
7Weeks Without Emptying16
Heated Air Drying The mop and dock base are dried completely with 60℃ (140℉) hot air15, preventing the growth of mold and unpleasant odors.
Auto Dust Emptying Supports auto dust emptying after cleanups and during cleanups, enhancing efficiency for heavy vacuuming and pet-friendly families.
Auto Tank Refilling Fills the robot water tank automatically when needed.
Reactive 3D Obstacle Avoidance Smart Enough to Stay Out of Troubles
Experience the seamless intelligence of the S8 Max Ultra, empowered by its advanced 3D structured light technology. With remarkable precision, it effortlessly detects and skillfully navigates around hazards. 42 Types of Objects Recognizable17
This is a image This is a image This is a image This is a image This is a image This is a image
Smart Suggestions for No-Go Zones Smart enough to suggest No-Go Zones automatically, your robot is kept safe from falling down the stairs accidentally, or getting stuck in tight spots.
Pet-Friendly Intelligence When approaching your beloved pets, it will immediately stop its main brush, and move aside in advance to prevent frightening your furry friends.
PreciSense® LiDAR Navigation Tailored for The Best Route PreciSense® LiDAR Navigation system scans and simultaneously creates detailed maps to determine the most efficient cleaning route, bringing a thorough and time-effective clean.
6x Faster18 Quick Mapping
3D Map Display
Multi-level19 Mapping System
Flexible for Your Needs, Anytime
  • Roborock SmartPlan™ Technology
  • Temporary Cleaning
  • Clean Along Floor Direction
With SmartPlan Mode on, you only need to choose the cleaning area and the S8 Max Ultra will take care of the rest. It will determine how to clean automatically based on the environment. The “Temp Cleaning” function swiftly handles unexpected spills without disrupting your usual cleaning schedule.
You can also utilize the “Temp Skip” feature to temporarily bypass cleaning specific areas as needed.
Achieve spotless cleanliness even in floor seams with the S8 Max Ultra, as it vacuums along the floor direction.
Roborock SmartPlan™ Technology With SmartPlan Mode on, you only need to choose the cleaning area and the S8 Max Ultra will take care of the rest. It will determine how to clean automatically based on the environment.
Clean Along Floor Direction Achieve spotless cleanliness even in floor seams with the S8 Max Ultra, as it vacuums along the floor direction.
Cleaning Access, Always Within Reach
S8 Max Ultra Robot 350 x 353 x 96.5 mm
Dock 409 x 419 x 470 mm
S8 Max Ultra with Refill & Drainage System Robot 350 x 353 x 96.5 mm
Dock 409 x 419 x 300 mm
This is a image FlexiArm Design™ Side Brush
This is a image DuoRoller Riser™ Brush
This is a image HyperForce® Suction
This is a image VibraRise® 3.0 Mopping System
This is a image Roborock Carpet Boost+ System™
This is a image Reactive 3D Obstacle Avoidance
This is a image Sensient® Sensor Array
This is a image Quiet Mopping
This is a image Child Lock
Stay Tuned Sign up for product availability alerts, exclusive offers, campaigns and more.
S8-Max-Ultra S8-MaxV-Ultra S7-Max-Ultra
S8 Max Ultra S8 MaxV Ultra S7 Max Ultra
Extra Edge Mopping System
8,000 Pa HyperForce® Suction
10,000 Pa HyperForce® Suction
5,500 Pa HyperForce® Suction
VibraRise® Mopping System
Reactive AI 2.0 Obstacle Recognition
DirTect™ Technolgy
Room Temperature Mop Washing
Intelligent Re-Wash and Re-Mop
S8-Max-Ultra
S8-Max-Ultra
S8 Max Ultra
S8-MaxV-Ultra
S8 MaxV Ultra
DirTect™ Technolgy
S7-Max-Ultra
S7 Max Ultra
  1. Based on Roborock internal testing according to IEC 62885-2:2021 / 5.11 standards, using Max+ mode with a full battery.
  2. The extendable side brush for sweeping low areas needs to be activated manually on the App.
  3. Certified No.1111279039 by TÜV Rheinland. Actual coverage depends on the environment.
  4. Based on Roborock internal testing. Actual results may vary depending on environmental factors.
  5. Based on Roborock internal testing, when selecting extreme water flow in custom mode, the mops can spin at a maximum speed of 185 rpm.
  6. Based on Roborock internal testing using Max+ mode. Actual results may vary according to the home environment.
  7. To clean the carpet one more time, select deep mode on carpet settings in the Roborock App.
  8. This applies only to carpets that have been recognized or manually added to the map by users.
  9. Based on Roborock internal testing. The term relates to the integrated mop module being able to be driven to produce high-speed reciprocating vibration of up to 4000 times/min, i.e. up to a frequency of 66Hz which is within a 'sonic' range (20 to 20,000Hz).
  10. Based on Roborock internal testing, the mop module can be lifted to 20mm above the ground.
  11. Compared to the Roborock S7. Based on Roborock internal testing. Actual results may vary according to the home environment.
  12. Based on Roborock internal tests, the water in the clean water tank can be heated up to 60°C at standard room temperature. The actual temperature will vary due to environmental factors.
  13. Based on testing carried out by TUV Rheinland on Staphylococcus aureus and Escherichia coli under default mode, over 99.99% of bacteria is effectively removed at the dock. Test Report number: 244555550b2 001. Actual results may vary according to the home environment.
  14. Based on Roborock internal testing using balanced mode. Actual results may vary depending on environmental factors.
  15. Based on Roborock internal testing. Actual results may vary depending on environmental factors.
  17. Based on Roborock internal testing, S8 Max Ultra can see and bypass objects down to as small as 5cm wide and 3cm tall. Recognition accuracy may vary depending on environmental factors.
  18. Compared to Clean&Mapping mode. Actual results may vary according to home environment.
  19. Up to four floors supported.
Your coupon code:
ROBOROCKS
Copy Code
