S8 Series
S8 Series
DuoRoller™ Brush
VibraRise® Mopping System
DuoRoller™ Brush
Auto Mop Washing
Auto Mop Drying
Auto Tank Refilling
DuoRoller Riser™ Brush
VibraRise® 2.0 Mopping System
s8plus
s8plus
S8 / S8+
Forget About Cleaning, Really.
Play Video LIVE Subscribe
Free your time and let the Roborock S8+ do the dirty work. Experience the next level of cleaning with our latest technology – DuoRoller™ Brush and VibraRise® Mopping System. Coupled with the RockDock® Plus, the smart cleaning experience has never been easier.
s8plus s8plus s8plus
This is a image DuoRoller™ Brush:
The Perfect Cleaning Duet
Hair? Dirt? Dust? Nowhere to Hide.
With the improved HyperForce® suction power of 6000 Pa1, even the smallest particles can be sucked up effortlessly by the Roborock S8.
Level Up Your Carpet Cleaning
Carpet cleaning is a breeze with Roborock Carpet Boost+ System
that’ll leave your carpet mess-free from pet hair to bread crumbs.
30%
Hair Pick-up Rate2
Vacuum Carpet First Supported.
See how Roborock Carpet Boost+ system works See how Roborock Carpet Boost+
system works
Step 1:
Step 2:
The mop lifts3 automatically and ensures not touching the carpet4 when cleaning.
Step 3:
DuoRoller™ brush and increased suction power help remove messes from carpets more effectively, enabling a thorough and deep cleaning experience by cleaning the carpets twice.5
  • Step 1:
  • Step 2:
  • Step 3:
VibraRise® Mopping System:
Mop with the Power of Sound3
Experience the power of sonic vibration technology that scrubs with consistent pressure to leave floors gleaming.
Learn More Learn More
3000times/min
6N
5mm
3000 times/min High-speed Scrubbing6
> 6N  Mop Pressure7
5mm  Mop Lifting3
> 6N  Mop Pressure7
5mm  Mop Lifting3
This is a image Reactive 3D Obstacle Avoidance:
Smart Enough to Stay Out of Troubles
With 3D structured light and infrared imaging technology, Reactive 3D Obstacle Avoidance system can help the robot vacuum identify and avoid potential hazards on the floors, in both bright and dark rooms, bringing you a worry-free cleaning experience.
Morning
Night
42Objects8
Power Strip Shoes
PreciSense®
LiDAR Navigation
The Best Route, Everytime
PreciSense®
LiDAR Navigation
Translation missing: en.s8Plus.section-eleven.title2
Translation missing: en.s8Plus.section-eleven.desc
Total Control Is a Tap Away
Map Quicker, Clean Faster
Experience fast and effective cleaning as your robot vacuum can create a map up to 6 times faster9 before the first cleaning task and can clean your daily area 30% faster10 when needed.
Automatically detects easy-to-get-stuck places and suggests No-Go Zones to prevent your robot vacuum from getting caught in small spaces. You can also draw Invisible Walls that block certain areas from your robot vacuum’s entry in the Roborock App.
Custom Cleaning Routines
Decide on your time when the robot vacuum cleans with custom cleaning schedules, and set cleaning routines for particular areas in the house regularly or on demand.
3D Mapping
The 3D Map allows you to accurately build your house virtually. And with the ability to add furniture, you can create the most detailed map of your house, ensuring that you get the best possible cleaning.
Multi-level Mapping System
Have a house with more than one floor? Multi-level mapping automatically recognizes distinct levels of your home. All you have to do is put the robot down. No additional docks or app identification is needed. Up to four floors supported.
  • This is a image This is a image
3D Mapping
This is a image Off-Peak Charging
7 Weeks
Handles Your
Dirty Work
After cleaning, the robot vacuum automatically empties itself into the 2.5L dust bag, storing up to 7 weeks11 of dirt and dust without manual intervention, helping you stay away from dirty work for longer.
*RockDock® Plus is only available with the Roborock S8+.
Handles Your
Dirty Work
7 Weeks
Dual Motor
Cleaning Power
Clean While
Emptying
Dual Motor
Cleaning Power
Clean While
Emptying
E12-Rated   Dust bag
2.5L   Capacity
  • This is a image DuoRoller™ Brush
    This is a image Sensient® Sensor Array
  • This is a image HyperForce® Suction
    This is a image Customizable App Control
  • This is a image VibraRise® Mopping System
  • This is a image PreciSense® LiDAR Navigation
    This is a image Child Lock
  • This is a image Reactive 3D Obstacle Avoidance
    This is a image Voice Control
S8 S8+ S8 Pro Ultra
Q7-Max-Plus Q7-Max Q7-Max
Auto Mop Washing
Auto Mop Drying
Auto Tank Refilling
DuoRoller™ Brush
DuoRoller™ Brush
Q7+   vs   Q7
S8
S8+
S8 Pro Ultra
DuoRoller™ Brush
DuoRoller™ Brush
Auto Mop Washing
Auto Mop Drying
Auto Tank Refilling
1. Based on internal testing carried out by the manufacturer according to IEC 62885-2:2016 / 5.8 standards, using Max+ mode with a full battery. Actual results may vary according to the home environment.
2. Compared to Roborock S7. Based on internal testing carried out by the manufacturer. Actual results may vary according to the home environment.
3. Based on internal testing carried out by the manufacturer, the mop module can be lifted up to 5mm.
4. Automatic mop lifting is only suitable for low-pile carpets not higher than 4mm. Alternatively, you can select avoid mode on the carpet settings in the Roborock and Mi Home App.
5. To clean the carpet twice, select deep mode on the carpet settings in the Roborock and Mi Home App.
6. Based on internal testing carried out by the manufacturer. The term relates to the integrated mop module being able to be driven to produce high-speed reciprocating vibration of up to 3000 times/min, i.e. up to a frequency of 50Hz which is within a “sonic” range (20 to 20,000Hz).
8. Based on internal testing carried out by the manufacturer, the S8 can see and bypass objects down to as small as 5cm wide, and 3cm tall. Recognition accuracy may vary depending on environmental factors.
9. Compared to Clean & Mapping mode. Actual results may vary according to the home environment.
10. Compared to standard cleaning route mode. Actual results may vary according to the home environment.
11. Actual emptying interval will depend on use habits and environmental factors.
3,000 times/min 30% more effective
Experience robot mopping like never before, with VibraRise® sonic vibration technology that scrubs your floors not hundreds, but thousands of times per minute. 3,000 times per minute to be exact. Combined with consistently high pressure, the VibraRise® system removes dried stains 30% more effectively than traditional robot mops and leaves less dirt behind than spinning mops.
Ready to Rise Up
When you want to mop, you don’t want to have to find and attach a mop cloth. Let alone the hassle of swapping your robot’s side brushes for mops. With VibraRise®, you don’t have to. With a tap on your phone, you can switch from vacuuming to mopping and back as often as you like.
Vac & Mop
Mop
Vacuum
Keep Clean Areas Clean
If you’ve got beautifully cleaned living room floors but your kitchen needs to be mopped, do you want that kitchen dirt dragged across your living room? No. Using VibraRise®, you can mop your kitchen and only your kitchen. Afterward, the robot will lift the mop and cruise back to its dock, leaving floors spotless.
Your coupon code:
ROBOROCKS
Copy Code
